Booking Appointments Plugin
smoove8
Post by smoove8 » Sat Aug 19, 2017 3:50 am
Hi, are there any plugins or features in the builder to allow people to book appointments through your website? Similar to Open Table.
Thanks,
Al
GrahamW
Re: Booking Appointments Plugin
Post by GrahamW » Sat Aug 19, 2017 4:38 am
I have used this in the past
https://www.shedul.com/
its a salon booking app but you can make it anything you like and it will integrate into anywebsite via a button or a form and the good thing its totally free
Graham
Post by BaconFries » Sat Aug 19, 2017 5:42 am
No not as such, you will need to use a external script for this just as GrahamW has mentioned. And if Open Table provides you with HTML and any relevant code you can bring into WWB using the HTML Object:
Adding HTML or Javascript to a web page
