Transparancy for drop down Responsive menu
chapy
Post by chapy » Wed Feb 27, 2019 8:45 pm
I am trying to use the Responsive Drop Down Menu in a Master page in the Header.
I would like to have the Menu to have a Transparant background color.
Is their a color combination (Red, Green, Blue) that would make the Background color of the Menu Transparent?
Leon Chapman
Chap
Re: Transparancy for drop down Responsive menu
Post by Pablo » Wed Feb 27, 2019 9:05 pm
You can adjust the alpha value of the color to make it transparent.
chapy
Post by chapy » Wed Feb 27, 2019 10:00 pm
I do not see any adjustment for Alpha value, it is just Reg, Green, Blue or Hue, Sat, Lum.
I am using the Responsive DropDown Menu, under Properties, on Tab Stlye.
For 1st Level menu >Background.
Selecting the drop down menu does not have any adjustments other than standard colors and Reg, Green, Blue or Hue, Sat, Lum
Chap
chapy
Post by chapy » Wed Feb 27, 2019 10:21 pm
In the Master_Page_Demo_layoutgrid.wbs, there is a menu called: "breadcrumb"
It has a transparency option.
I do not find the breadcrumb menu as an extension???
Is it available??
Chap
Post by BaconFries » Wed Feb 27, 2019 11:45 pm
This feature is available in WB14.x.x
Are you sure it is a extension and not the Breadcrumbs Object found in Navigation?
chapy
Post by chapy » Thu Feb 28, 2019 12:47 am
Ok, I found the Breadcrumb Navigation extension. Thanks.
I am using the latest version: WB 14.3.2.
I can do what I need to do with the Responsive menu or the Panel Menu.
Thanks for your help!
Chap
Post by Pablo » Thu Feb 28, 2019 7:01 am
Post by zinc » Thu Feb 28, 2019 8:23 am
Apologies to Chapy & you Pablo for hijacking this thread, is there anyway to be able to enter the value in the colour slider as sometimes it is very hard to get the right value using a mouse.
Post by Pablo » Thu Feb 28, 2019 8:31 am
Select 'More colors' to set the exact values.
Post by zinc » Thu Feb 28, 2019 8:37 am
Oh Yes! I had forgotten about that. Cheers Pablo.
chapy
Post by chapy » Thu Feb 28, 2019 10:26 pm
The problem is with the PAID Extension called:
Responsive Drop Down Menu.
It does not have an Alpha slider in the color graphic that Pablo posted.
Has there been an update to that extension that has added the Alpha Slider??
If so, how can I download and install?
Chap
Post by Pablo » Fri Mar 01, 2019 7:25 am
I'm sorry, this feature is not available in the Responsive Drop Down Menu.
