page's shaking during the scrolling down
alg21
Post by alg21 » Fri Dec 21, 2018 2:53 pm
Hi Pablo!
I've met a sudden problem, can't find a solution.
project http://prokat-oz.ru
then you open it in mobile browser's (mainly Google's browser. In Firefox it happends rarely) , during scroll down the pages it starts to shake and page can't be scrolled down to end of the page at all after that.
Can you give an advise, how to solve it?
Thank's in advance!
p.s. I use WB14
Re: page's shaking during the scrolling down
Post by Pablo » Fri Dec 21, 2018 3:48 pm
I do not see any issues. What exactly do I need to do to see the problem?
Tip: remove all custom/third party code. I cannot give support on pages that have custom code.
Post by BaconFries » Sat Dec 22, 2018 2:35 am
This is most likely related to the use of the parallax effect. Note not all mobile browsers support this. Try temporarily removing the effect and see if that resolves it if it does then you can disable parallax for smaller screens. Also just as Pablo please remove all code added by yourself this includes the yandex counter and the following страница1Html1
alg21
Post by alg21 » Sat Dec 22, 2018 6:17 am
Thank you for reply!
Yes, the problem was with Parallax. I deleted it from the Layer and issue have been solved after it. Thank you for you advise!
But it is curious, because that layer with Parallax "Слой_тело_1240" is switched off on 320px pages..
http://joxi.ru/zANG56ysBPJZXr - fullwidth page
http://joxi.ru/BA0N4GMHJ3lVXm - 320px page
How does Parallax layer can involve on 320px page in this case?
I would like to keep Parallax alive on full-screen pages, not to delete it from the whole project. Is it possible?
Post by Pablo » Sat Dec 22, 2018 7:43 am
You can set a different background mode for the smaller breakpoint.
