LayoutGrid section visibility
madebyibloo
Post by madebyibloo » Mon Nov 05, 2018 4:37 pm
Hi Pablo,
I cannot seem to get the 'visible' to work in a layoutgrid as it did before.
Object: Layoutgrid
Default BP: 970
BP: 580
On the default breakpoint. when I highlight a section and untick 'visible' it becomes blanked out, this is normal.
then when I go to bp 580, its the same as bp 970?
It does not seem to be remembering the visible (ticked/unticked) in all bp's. you do it it one bp and it does it for all bp's.
Cheers,
Scott
Re: LayoutGrid section visibility
Post by Pablo » Mon Nov 05, 2018 4:51 pm
Maybe you have unchecked 'include visibility'?
madebyibloo
Post by madebyibloo » Mon Nov 05, 2018 4:57 pm
That is ticked in Options/General. I have tried it with and without.
I have even started a blank project and it still does the same, it doesn't seem to remembering in different bp's.
Cheers,
Scott
madebyibloo
Post by madebyibloo » Mon Nov 05, 2018 5:22 pm
Also, column width is not being remembered in different bp's.
Cheers,
Scott
madebyibloo
Post by madebyibloo » Mon Nov 05, 2018 5:32 pm
Sorry Pablo, found it.
Overflow needs to be set to 'hidden'.
It defaults to 'none'.
'visible' and 'column size' now adjusts in different breakpoints when set to 'hidden'.
Cheers,
Scott
Post by Pablo » Mon Nov 05, 2018 6:02 pm
Correct. Note that this is documented in the help.
madebyibloo
Post by madebyibloo » Mon Nov 05, 2018 6:20 pm
Thanks Pablo, I can't believe I missed this as I've used lg's since day 1!!! I've just kicked myself!
A suggestion maybe...
If set to 'none' - disable the 'visible' checkbox.
Or even better...
Set the default to 'hidden' - that way the end user can use all effects in breakpoints without having to change any settings?
Cheers,
Scott
Post by Pablo » Mon Nov 05, 2018 6:57 pm
I have intentionally set the default to none, to be compatible with previous versions where overflow was not supported.
