Floating Layers and Layer Grids
Lasa
Post by Lasa » Sat Oct 27, 2018 8:30 pm
I just noticed that Floating Layers and Layer Grids can actually coexist on a page as long as you build in breakpoints...
This software is amazing! Now if I can wrap my head around all the options.
Cheers
Re: Floating Layers and Layer Grids
Post by Pablo » Sat Oct 27, 2018 9:28 pm
Correct, many of the example templates demonstrate this functionality.
Lasa
Post by Lasa » Mon Oct 29, 2018 10:28 pm
I'm not sure if this is correct... but,
It seems that layer grids only adapts to the single in grid break point.
It does not seem to abide by page added break points.
Is this correct?
Cheers,
Lasa
Post by crispy68 » Tue Oct 30, 2018 12:44 am
layout grids have their own breakpoint where the grid switches from horizontal to vertical (stacked mode). Typically, you will set the bp of the grid to switch when the content within no longer looks good and needs switched to stacked mode. You can also nest 1 layout grid within another which give you more flexibility in how things switch when the screen gets smaller.
Lasa
Post by Lasa » Tue Oct 30, 2018 1:25 pm
Thanks...testing testing testing.. :D
