*** SOLVED *** "cssmenu"
Tommaso
Post by Tommaso » Fri Jul 20, 2018 12:12 pm
having some problem with my CSSmenu (inside a layout grid)
from desktop it work perfectly fine (from WB: https://imgur.com/hDto0yg from Google:https://imgur.com/3rwjusM)
but from mobile/small-sized-window it bug out! (from WB ITS LOOK LIKE ITS FINE: https://imgur.com/5WCF0av and then on google.. https://imgur.com/7kTRmzb)
i cant understand if its just a bug or i'm missing something...
Re: "cssmenu" maybe bugged?
Post by Pablo » Fri Jul 20, 2018 12:15 pm
Sorry, but you will have to be more specific.
What is the exact problem?
What is the URL of the page?
What do I need to do to see the problem?
Note that there are no known bugs in the CSS menu otherwise they would have already been fixed.
Tommaso
Post by Tommaso » Fri Jul 20, 2018 12:26 pm
link page! http://www.martel-it.com/prova_sito_201 ... xt%29.html
in the meantime i was trying to find out the problem by using the "inspect element" tools from google, and i found it! https://imgur.com/5s41FjH dunno why but the layout have that "text-align:left" even if in the option i set it on center! This is a screenshot of the options window https://imgur.com/LzObPFJ !
what am i missing Paoblo? i'm feeling dumb, sorry for asking so many stupid questions, i'm just not into programming...
Post by Pablo » Fri Jul 20, 2018 12:32 pm
The alignment of the layout grid column seems to be set to 'left'
Note that the alignment can be different in breakpoints, so you may have only set it to center in the default view.
Tommaso
Post by Tommaso » Fri Jul 20, 2018 12:40 pm
Fixed, but i swear i'm SURE that it was already set on 'center' in both visualizations!
thanks anyway
