Mobile sites do not work properly
Marek
Post by Marek » Fri Apr 20, 2018 11:50 am
Could you give me an advice please. I'm learning to create pages through WYSIWYG responsive. The basic page is fine.
Mobile menus do not appear on the mobile site, and there is also a menu for larger sites. There is also no text in the footer and the text on the page is blurred. Can you please advise me where I'm making a mistake?
https://www.mdata.cz/test/
Project to download here:
https://www.mdata.cz/test/test.zip
Thank
Re: Mobile sites do not work properly
Post by Pablo » Fri Apr 20, 2018 12:16 pm
There are objects outside the viewport.
For example, object "TextDefault''
See also the FAQ: (There is a large is empty space at the bottom (or right side) of my page)
Marek
Post by Marek » Sat Apr 21, 2018 6:31 am
I have modified the project, but I still do not know the advice. The "TextDefault" object is too long to always exceed.
768 - Object "MenuDefault" is displayed, which is skyrocketed. The "Menu768" object is not visible, which is visible. The "TextVPaticceMobil" object does not appear in the footer. The "TextVPaticceDefault" object is invisible, can not be found when it is visible.
480 - Object "MenuDefault" is displayed, which is skyrocketed. The "Menu768" object is not visible, which is visible. The "TextVPaticceMobil" object does not appear in the footer. The "TextVPaticceDefault" object is invisible, can not be found when it is visible.
320 - Object "MenuDefault" is displayed, which is skyrocketed. The "MenuMobil" object is not visible, which is visible. The "TextVPaticceMobil" object does not appear in the footer. The "TextMobil" object is not displayed. The "TextVPaticceDefault" object is invisible, can not be found when it is visible.
Please help me with this, I can not get out of it.
Post by Pablo » Sat Apr 21, 2018 7:11 am
- Display the Object Manager
- Go to the 320 breakpoint
- Make 'TextDefault' visible
- right click the object and select 'Reset position'
- resize the object so it fits inside the 320 viewport.
- hide the object again.
Do this for all objects that are not inside the viewport.
Marek
Post by Marek » Sat Apr 21, 2018 7:45 am
Thank you, the text is fine. The menu above and the footer is not correct. The mobile menu is not visible on the page and the default menu appears
Post by Pablo » Sat Apr 21, 2018 9:49 am
If an object is outside the current viewport then you can use 'Reset Position ' in the Object Manager to move it into view.
- select 'Reset Position'
See also the FAQ:
