*SOLVED* Responsive Menu widening some pages but not others
etcbbu
Post by etcbbu » Fri Mar 16, 2018 4:26 pm
Please look at all of this from a Mobile-browser, or at least, a browser window of 320-pixels, because it is at my 320-Width Breakpoint that I am seeing this happen:
Notice how everything looks fine if you look at these two pages:
http://s729539929.onlinehome.us/index.php
http://s729539929.onlinehome.us/gallery.php
You do not have the ability to "pan right" or "scroll right" beyond the content of the page, as if there is a not-Visible object that's back-loading and causing the page-width to artificially be bigger.
But if you look at almost any of the other pages on the website, like, say,
http://s729539929.onlinehome.us/cartsales.php
The Responsive Menu at the top of the page seems to have a larger width, or something, somehow, for some reason; which, I believe, in turn is causing the ability to "pan right" or "scroll right" beyond the content of the page, as if there is a not-Visible object that's back-loading and causing the page-width to artificially be bigger.
I'm using the same "Page Header" object on every page of this website, and the only child-object in that "Page Header" is a "Master Object" which calls a masterpage that I have just that Responsive Menu on. So I don't know why it would be doing this on different pages when they're all calling the same menu in the same way..?
www.ktravisj.com
Travis J Consulting, LLC -
Website Design/Development/Maintenance, Web-Marketing/Social Media/Social Networking, SEO/Search Engine Optimization
www.ktravisj.com
Re: Responsive Menu widening some pages but not others
Post by Pablo » Fri Mar 16, 2018 6:07 pm
Does the page have the same breakpoints as the master page?
etcbbu
Post by etcbbu » Mon Mar 19, 2018 2:13 pm
Yes, every page on the website has a Default, 970-width breakpoint and also a 320-width breakpoint, including all of the masterpages.
Here is a screenshot of that "masterpage6" , which holds the Responsive Menu:
www.thecartshed.com/scrn13192018.png
The only other thing I can think that is different is that the Homepage is constructed with non-Floating Layers, while the rest of the pages of the website *are* constructed with Floating Layers. *BUT*, the "Cart Sales" page, at www.thecartshed.com/cartsales.php , is functioning just fine and not having the little scrollable-space out to the right, it's constructed with Floating Layers.
Would it be helpful for you to see my .WBS file?
--etcbbu
www.ktravisj.com
www.ktravisj.com
etcbbu
Post by etcbbu » Mon Mar 19, 2018 2:37 pm
Well, think I figured out a solution. On the "Custom Carts" and "New Carts" pages, http://thecartshed.com/customcarts.php and http://thecartshed.com/newcarts.php , I went ahead and just gave every object on the page a new "Object ID" that sort of falls into the nomenclature of that page, and relative to all of the rest of the Objects within that page in WB. Then I published those two pages. Now, when I visit them on a Mobile device, seems like it's not doing the scroll-right thing anymore. So, looks like I may have found the fix. I'll just do this on the rest of the pages of the site.
Thanks! :D :D :D WB RULES! :D :D :D
--etcbbu
www.ktravisj.com
www.ktravisj.com
etcbbu
Post by etcbbu » Thu Mar 22, 2018 8:02 pm
I've still got *ONE* page that's doing this. Can someone visit this page on a smartphone:
http://thecartshed.com/batteries.php
And maybe help me figure out what object is causing the page to be able to load more than just a 320-pixel width and let me scroll right?
--etcbbu
www.ktravisj.com
www.ktravisj.com
Post by Pablo » Thu Mar 22, 2018 9:22 pm
I do not see any issues with this page.
However, but here is a suggestion:
remove objects from the page one by one until you found that one that is accusing project.
etcbbu
Post by etcbbu » Fri Mar 23, 2018 7:55 pm
Well. I found it. My
thecartshedbatteriesimage9
Was a ghost-object, somehow. Deleted it. All appears to be well!
--etcbbu
www.ktravisj.com
www.ktravisj.com
wmyatt
Re: *SOLVED* Responsive Menu widening some pages but not others
Post by wmyatt » Wed Mar 28, 2018 8:39 pm
I like that menu. How do you obtain that?
etcbbu
Post by etcbbu » Fri Mar 30, 2018 6:00 am
@wmyatt : Look on the left-side of your screen where all of your tools/objects are. Look for the heading entitled "Navigation". The name of the tool is "Responsive Menu".
--etcbbu
www.ktravisj.com
www.ktravisj.com
