Problem with Parallax across multiple Breakpoints
Re: Problem with Parallax across multiple Breakpoints
Post by Pablo » Wed Feb 14, 2018 9:38 pm
Sorry, it still does not look good.
But, I have done some experiments and it turn outs for the iPad the aspect ratio of the image needs to be 4:3
etcbbu
Post by etcbbu » Wed Feb 14, 2018 9:52 pm
Ok, what about the second page?
http://www.phenixlawfirm.com/test/aboutus.php
When you test it on an iPad, does it load my third, new, 768-Breakpoint and look ok?
www.ktravisj.com
Travis J Consulting, LLC -
Website Design/Development/Maintenance, Web-Marketing/Social Media/Social/Networking, SEO/Search Engine Optimization
www.ktravisj.com
Post by Pablo » Wed Feb 14, 2018 9:56 pm
I don't think the iPad will use the 768 breakpoint.
etcbbu
Post by etcbbu » Wed Feb 14, 2018 10:14 pm
So, let's say since I want my page to be 970 pixels-wide, should I try to use an image whose dimensions are
970 Pixels Wide
725 Pixels Tall
And then I also make the Layer that holds the image
970 Pixels Wide
725 Pixels Tall
Is that what you are suggesting? Would that be the 4:3 you are suggesting?
www.ktravisj.com
www.ktravisj.com
etcbbu
Post by etcbbu » Wed Feb 14, 2018 10:52 pm
Because, if you can please use an iPad to check it on an iPad now,
http://www.phenixlawfirm.com/test/index.php
I have made both of the Layers' images
970 Pixels Wide
725 Pixels Tall
And then I also made the Layer that holds the image
970 Pixels Wide
725 Pixels Tall
And I would like to know if I am trying this new 4:3 ratio correctly, that you said, and if this worked to make it look better or not.
www.ktravisj.com
www.ktravisj.com
etcbbu
Post by etcbbu » Thu Feb 15, 2018 5:45 am
Anyone with an iPad, please to check it on an iPad for me,
970 Pixels Wide
725 Pixels Tall
970 Pixels Wide
725 Pixels Tall
This is my final attempt, If this didn't do it, I will be using solid-color layers, and just place Images on it as a child.
Someone please just let me know if these are acting right or not.
www.ktravisj.com
www.ktravisj.com
Post by Pablo » Thu Feb 15, 2018 7:12 am
It think the image should be
970 Pixels wide
1294 Pixels tall
Please do not change anything else, only the image.
etcbbu
Post by etcbbu » Thu Feb 15, 2018 3:31 pm
Ok, I have made the change to both of the Layer images in this page:
I did *not* change the Layer size to
970 Pixels wide
1294 Pixels tall
Please look at it, in its current state; on an iPad, and let me know what happens.
Please let me know if I need to *also* change the Layers sizes to
970 Pixels wide
1294 Pixels tall
Just like the images, and then we can look at that change next, if needed.
www.ktravisj.com
www.ktravisj.com
Post by Pablo » Thu Feb 15, 2018 4:46 pm
Sorry, it still doesn't work.
However when I use the same image in the template then it works on the iPad.
http://wysiwygwebbuilder.com/support/etcbbu/
I suggest to download the 'features' template and check out the differences with your own settings.
http://wysiwygwebbuilder.com/templates0.html
etcbbu
Post by etcbbu » Thu Feb 15, 2018 5:08 pm
Ok, I have made the change to make my two alter-images on this page
Match the options of the Layers in the Template that you said.
Also, could it have to do with the version of "jQuery" or "PHP"? Could that affect things?
www.ktravisj.com
www.ktravisj.com
etcbbu
Post by etcbbu » Thu Feb 15, 2018 5:32 pm
Because I have my
index.php page's jQuery version set to jquery-2.2.4.min.js and the PHP version set to PHP7.
Whereas the "features" template's "Wb11_features" template file is set to jQery version jquery-1.12.4.min.js and the PHP version set to PHP5.
Could that be a difference that I need to change? But, I will not execute that yet. Could someone Please look at http://www.phenixlawfirm.com/test/index.php , in its current state; on an iPad, and let me know what happens?
www.ktravisj.com
www.ktravisj.com
Post by Pablo » Thu Feb 15, 2018 5:51 pm
No, it has nothing to do with the version of PHP or jQuery.
etcbbu
Post by etcbbu » Thu Feb 15, 2018 6:00 pm
Is it still not working when you look at it now?
www.ktravisj.com
www.ktravisj.com
Post by Pablo » Thu Feb 15, 2018 6:08 pm
No, it still doesn't work.
etcbbu
Post by etcbbu » Thu Feb 15, 2018 6:19 pm
All right, then I have no idea what else to do. I'm just going to do solid-color Layers, and place them as Images sitting as Child-objects in the solid-color layers.
Thanks for helping me test it, and for the ideas, anyway, Pablo.
--etcbbu
www.ktravisj.com
www.ktravisj.com
