Header
kenmed
Header
Post by kenmed » Sun Nov 12, 2017 11:47 am
Hi
I try to place a header and make it stick, and under that a layout grid or a flexboxcontainer. It does not work.
Added a meny bar inside grid and f-container inside but did not showed up in preview or in published.
Does it not work with mixing header/footer with grid/fcountainer?
Kenneth
Re: Header
Post by Pablo » Sun Nov 12, 2017 12:01 pm
A page header is always the first item on the page, so you cannot place it under a layout grid.
Examples:
http://www.wysiwygwebbuilder.com/templates0.html
kenmed
Re: Header
Post by kenmed » Sun Nov 12, 2017 12:16 pm
Not sure if I got it. I place a header first on the page and below that I insert a grid/fcountainer and try to build from there.
I wish to have a header that stays and build the rest with grid/fcountainer. The header stays but nothing else can be seen.
A guide in the right direction please and I try find out how to do it.
Kenneth
Re: Header
Post by Pablo » Sun Nov 12, 2017 12:58 pm
Did you check out the templates?
kenmed
Re: Header
Post by kenmed » Sun Nov 12, 2017 1:07 pm
Ok, I will check them.
ken
kenmed
Re: Header
Post by kenmed » Sun Nov 12, 2017 6:19 pm
www.aikiken.se
A header, a responsive meny, layoutgrid and and a picture. Only half picture appears? In the next grid it shows the whole picture. Same settings in the grids.
Ken
Re: Header
Post by Pablo » Sun Nov 12, 2017 6:37 pm
The header is fixed so it will be displayed on top of all other content. This is normal HTML behavior.
If you want to add an offset, so the header does not cover the first element in the layout, then you can add a margin at the top of that element.
kenmed
Re: Header
Post by kenmed » Sun Nov 12, 2017 6:52 pm
Ok. But way does not the grid respect the boarder of the header and display the content as the grid nr 2 does?
Thanks.
Re: Header
Post by Pablo » Sun Nov 12, 2017 6:54 pm
If you add a margin to the first grid then all other grids will automatically move down.
kenmed
Re: Header
Post by kenmed » Sun Nov 12, 2017 7:11 pm
Ok. Seems to work.
Keep learning. Great support as always. Read the supportpage more than working with pages. A great team there!
ken
kenmed
Re: Header
Post by kenmed » Mon Nov 13, 2017 7:52 pm
I put a flexboxcontainer or a grid, add a picture, next layoutgrid, add same picture. Have do set padding to 100 in grid so I can see the picture in prev.
Why?
www.aikiken.se is build this way. Reviewlink shows picture with 2 layoutgrid and padding 100 so I can see the pictures.
ken
Re: Header
Post by Pablo » Mon Nov 13, 2017 9:09 pm
I'm sorry it is not clear what your question is.
kenmed
Re: Header
Post by kenmed » Tue Nov 14, 2017 5:51 am
i be back later trying to explain.
ken
kenmed
Re: Header
Post by kenmed » Tue Nov 14, 2017 4:11 pm
Have done some trial and error and getting a little knowhow about it. Coming back.
ken
Users browsing this forum: No registered users and 6 guests
