Apply images/logo on top of background image
Hi Guys,
As for this website [www.demo.atbc2018.org] I only place the logo and the bird photo on top of the motif background.
Only motif background is with layout grid.
Am I doing the right thing? since I want it to be responsive, I have to rearrange for all the breakpoint one by one,
any other way to do to save more time...
Thanks again
Newbies
Thanks again
Newbies
Re: Apply images/logo on top of background image
The page header uses 'fixed' layout so in that case you will have to implement breakpoints to make it responsive.
If you only use layout grids then most content will be responsive by default.
Related FAQ:
http://wysiwygwebbuilder.com/forum/view ... 10&t=76722
Related FAQ:
Hi Pablo,
mean I can't insert page header + layout gird.
only apply layout grid to create own page header right?
Then how do apply logo on top of the layout grid itself? with the motif full background
The page header should not be inside a layout grid. The header is container itself.
Noted on that.
Thanks for the sharing.
On the responsive menu, how do I apply so that when on click, the menu will push up/down the content? not overlap header content/ image
same as wysiwg layout @ 320 breakpoint
In that case the menu should be inside a layout grid, it needs to be floating to affect the rest of the layout.On the responsive menu, how do I apply so that when on click, the menu will push up/down the content? not overlap header content/ image
Hi Pablo,
Thanks again for the sharing.
On the google analytics, I I did insert the code on the html <!-- UA-109541484-1 --> but on my google account no record.
Any missed here?
Any missed here?
Maybe you have added the code in the wrong place?
Or maybe the code is incomplete?
Are you sure this all the code you will need to add?
My bad.... I missed the full code..... thought only ID track to be insert
Thanks again for all the favor and guideline.
Cheers man
Cheers man
Users browsing this forum: No registered users and 6 guests
