text box issue
GrahamW
text box issue
Post by GrahamW » Tue Oct 24, 2017 2:01 am
I have a layer on a page set to 1200 wide and on that layer I placed a text box then typed in my text. However the text when you view the site is outside the layer and text box.
When you look at it in the design window it is all contained with the text box and the text box is within the layer as it normally would be
To see what I mean see this link. I have set colours on the layer and text box for easy viewing, they are not normally there
https://www.grahamscomputers.net/terms.html
Yellow is the layer
Green is the text box.
I originally typed the document in word then copied and pasted into my text box. Could this be my issue why the text wont retain to the textbox.
Graham
Re: text box issue
Post by [RZ] » Tue Oct 24, 2017 4:04 am
you selected 'output format: use <div>...etc' for the text element
select 'default' or 'include line-height...'
GrahamW
Re: text box issue
Post by GrahamW » Tue Oct 24, 2017 5:14 am
Hi RZ
its already set on default for the output
Graham
Re: text box issue
Post by Pablo » Tue Oct 24, 2017 5:56 am
You have added 'indent' to the text, this will force each line to have a fixed length.
Please remove the indent from the text.
GrahamW
Re: text box issue
Post by GrahamW » Tue Oct 24, 2017 8:03 am
Thankyou Pablo that fixed it.
this is why your paid the big bucks to proble solve.
Graham
Users browsing this forum: No registered users and 7 guests
