[rz] Popup Container
Post by [RZ] » Wed Aug 22, 2018 1:02 pm
[rz] Popup Container v1.0
The easiest solution to convert objects into synchronized popup elements in the page activated by buttons.
Some features:
- Highly customizable buttons based on text, images or both.
- Customizable container to embed/hold the converted elements.
- Multiple button positions with different margins.
- Automatic popup reposition based on the button location.
- Multiple instances to manage several popup elements.
- Smartly synchronized elements by z-order or by closing objects.
- RWD support.
- Cross-platform and maximum backward compatibility.
- Lightweight without dependencies.
...and much more!
HTML 4.01 Transitional
W3C compliant
DEMO
How to use?
1. Design the element/s on your page as you usually do.
2. Drag and drop the extension instance/s.
3. Enter the object/s name/s to convert it/them into popup element/s.
4. Optionally, change the default settings for the ones that fit your scheme.
5. Preview or publish.
Enjoy!
Re: [rz] Popup Container
Post by zinc » Wed Aug 22, 2018 1:24 pm
Thanks for doing this RZ!!! Welcome to new modern UI/UX!!!!
Post by [RZ] » Wed Aug 22, 2018 1:30 pm
thanks for your kind words!
