[rz] Simple Timeline *** UPD 2018-Apr-26 ***
Post by [RZ] » Tue Jun 06, 2017 4:57 pm
[rz] Simple Timeline v1.1
This versatile and highly customizable extension allows you to create a series of elements in a simple timeline style.
Some features:
- Horizontal and vertical orientation.
- Smart overflow control.
- Group, header, caption, image, content and footer structure.
- Custom colors, borders, fonts, alignments, etc.
- RWD and fluid schemes support with advanced auto-resize.
- Maximum backward and cross-browser compatibility.
- Lightweight and instant startup.
- No jQuery required.
...and more!
HTML 4.01 Transitional
W3C compliant
DEMO
* New in version 1.1
- Three modes: always opened, start opened, start closed.
- Custom colors for the different statuses.
- Quicker startup and minor code improvements.
How to use?
1. Drag and drop the extension to the workspace and enter its scheme and parameters so as to make it fit your design.
2. Resize the instance to determine the elements size; applies to both fluid and RWD scenarios.
3. Preview or publish.
Enjoy!
Re: [rz] Simple Timeline *** UPD 2018-Apr-26 ***
Post by [RZ] » Thu Apr 26, 2018 11:57 am
GrahamW
Post by GrahamW » Sat Apr 28, 2018 5:37 am
looks good RZ, Can you add images and word wrap text around them or does the image placement go next to the text
