[rz] Background Images II *** UPD 2018-Dec-31 ***
Re: [rz] Background Images II *** UPD 2018-Jan-17 ***
* New in version 2.0.1
- Navigation dots can optionally have customizable ordinal numbers for the images, uppercased/lowercased letters or roman numbers; these dots can be colored, image-based or thumbnails based.
- Improved color setup for the navigation dots.
A Total GEM!!!!!! Thank you RZ!
thank you for your support
Re: [rz] Background Images II *** UPD 2018-May-11 ***
* New in version 2.0.2
- Selectable specific scripts for new wb14 Carousel variants.
- Minor script improvements.
thank <you> for supporting my hard work behind the scenes!
Re: [rz] Background Images II *** UPD 2018-Jun-02 ***
* New in version 2.1
- Improved slide effect; now it behaves normal or cycled (resulting in eight modes).
- Image-specific background color (meaningful with cycle-based effects and with slight opacities for background tint simulation).
- Space around the instance in percentages and/or pixels; this allows to setup the background areas to not be covered.
- Fixed a minor blur transition issue on Edge.
- Fixed a minor z-order issue in layers with other relative elements on some browsers.
- Minor code optimizations.
- New extension: [rz] Background Images (synchro); it allows to start all the [rz] Background Images instances in the same page at the same time once all of them are ready and their images have been loaded.
Thank you so much for the implementing my requests. Most grateful!!!!
Is the license for a website developer a per site license? ie i develop for customers, is a license required for each customer website I use background images?
thanks
thanks
please contact privately for details
(following the links below this post)
Re: [rz] Background Images II *** UPD 2018-Dec-31 ***
* New in version 2.1.0.1
- Horizonal and/or vertical offsets for the dots specific to the current image.
thank you for your kind feedback
