[rz] Align Object *** UPD 2018-Jun-15 ***
Re: [rz] Align Object *** UPD 2017-Mar-13 ***
Post by [RZ] » Mon Mar 13, 2017 2:24 pm
* New in version 1.1.1
- Smoother startup.
- Improved center alignment on complex scenarios.
Post by zinc » Mon Mar 13, 2017 4:24 pm
- Smoother startup.
Now we are cooking with Gaz!!!!! Thank you.
Post by [RZ] » Mon Mar 13, 2017 4:34 pm
lol thank you for your kind feedback
Re: [rz] Align Object *** UPD 2017-Apr-12 ***
Post by [RZ] » Wed Apr 12, 2017 12:08 am
* New in version 1.2
- Improved elements centering/handling based on a better detection of the container parameters.
- Improved behavior with [rz] Position Object Size when both instances has same targets.
Post by zinc » Tue Apr 17, 2018 3:17 pm
This is by far one of the BEST extensions, I have come across. I just had to align more than 20 different objects in different directions within several layers on one page. Outstanding RZ!!!!
Post by [RZ] » Tue Apr 17, 2018 4:12 pm
thank you :)
Re: [rz] Align Object *** UPD 2018-Jun-01 ***
Post by [RZ] » Thu May 31, 2018 10:16 pm
* New in version 1.3
- Minor code tweaks.
- New extension: [rz] Align Object (RWD); it allows to align objects in their containers and supports different alignments in different breakpoints.
Post by zinc » Fri Jun 01, 2018 7:36 am
Thank you once again for responding to my request!!! :D
RiaanN
Post by RiaanN » Fri Jun 01, 2018 9:58 am
Hi [rz]
Do you take on extension requests ?
Regards
Riaan
Post by [RZ] » Fri Jun 01, 2018 10:10 am
if your question is "bespoke" extensions and/or scripts, yes sir
just get in contact following the links below this post (on the signature) and use the form
Re: [rz] Align Object *** UPD 2018-Jun-15 ***
Post by [RZ] » Fri Jun 15, 2018 6:43 am
* New in version 1.3.1
- Added support to panel-layers.
Post by zinc » Fri Jun 15, 2018 2:54 pm
Thank you for sorting this out in such short notice!!!! :D
Post by [RZ] » Fri Jun 15, 2018 3:27 pm
many thanks to you for your constant appreciation of the hard work behind the scenes :)
