[rz] Shopping Suite *** UPD 2020-Jan-05 ***
Re: [rz] Shopping Suite *** UPD 2015-Jan-01 ***
Post by [RZ] » Thu Jan 01, 2015 2:10 pm
hello supersonictt
the online demo has some extras that come with the suite version plus the [rz] Flat Side Menu
the included demo does not use any extra, it is 100% based on standard wb objects and of course the extensions that come with the essentials version
the only thing you need is upload to the server and the server must support php
if you do not want to support pay on delivery, you do not need php nor mysql
if you want to support p-o-d, you will need php for the signup, login, details form, signup, etc, but if you configure these objects -within wb- to be mysql based, then you need php and mysql, but all this is up to you
in just a few words, yes, you will be able to do the same as in the online demo, except the nice alerts and confirmation boxes, or the nice tooltips, but if you have the diamond pack you will be able to do a nicer application than the dull demo you are referring to :)
supersonictt
Post by supersonictt » Thu Jan 01, 2015 2:18 pm
Well, I purchased the Platinum pack, remember? ;)
So I guess I just need the essential suite and the p-o-d extension, right?
What I meant in my previous post: as soon as the customer enters his username and password and then re-directed to the check-out (the form page), all his info are automatically filled in the form. Well, is this specific feature included in the extension sample demo? Or did you add extra codes to do that in the live demo?
I know how to deal with the login tools in WWB, so do not worry about that :)
Thanks again
Post by [RZ] » Thu Jan 01, 2015 2:24 pm
i guess you will need the [rz] CBO to comply with the EU eprivacy rules
if you are planning a rwd scenario, you may need to upgrade your pack
yes, the sample included can do all the process as you see in the online demo
take that sample as a sort of "tutorial" just in case you may need assistance, as we could talk in the same language :)
but you said that you can deal with wb login tools, so i'm pretty sure you won't be facing any issue
(check the included extensions in both packages and compare with what you have, and make your decision)
supersonictt
Post by supersonictt » Thu Jan 01, 2015 3:23 pm
Thanks a lot, yes I guess the included sample will explain everything :)
I will see what extensions I have and get the rest.
Thanks a lot :)
Re: [rz] Shopping Suite *** UPD 2015-Feb-18 ***
Post by [RZ] » Wed Feb 18, 2015 12:13 pm
* New in version 1.0.3.1:
- Improved actions/buttons for iOS-based touch devices.
- Fixed the focus handling in [rz] Shopping (b-monitor) module.
- Fixed a sporadic interference between [rz] Shopping (checkout) and [rz] Shopping (b-monitor) modules.
- The empty cart button is not shown when the ordered products list is empty.
- Improved HTML generation in [rz] Shopping extension.
- Improved image handling in actions icons and other minor code tweaks.
Re: [rz] Shopping Suite *** UPD 2015-Apr-07 ***
Post by [RZ] » Tue Apr 07, 2015 9:25 am
* New in version 1.0.3.2:
- Grouped products feature allows to include only one product per group excluding any other ordered product of the same group.
- Improved startup for long carts ("fast" and "on ready" modes, useful for non-cached pages with a considerable amount of products).
mayur007
Post by mayur007 » Fri Apr 17, 2015 7:51 pm
hi rz i looking for this b ut i have query i feel that your magnashop is heavy i mean takes time to load does it have light verison
i m experincing thats why
Post by [RZ] » Sat Apr 18, 2015 5:14 pm
it is due to an experimental extra service that has been added for loyal supporters and customers
in this case, nothing related to the extensions themselves and their performance
mayur007
Post by mayur007 » Sat Apr 18, 2015 8:48 pm
so you mean extension is light and fast correct ?
Post by [RZ] » Sat Apr 18, 2015 8:52 pm
[RZ] wrote:it is due to an experimental extra service that has been added for loyal supporters and customers
mayur007
Post by mayur007 » Sun Apr 19, 2015 8:38 pm
hi
rz i dont know much
but i need to ask bcoz i have queries
http://www.magnawebstudio.com/shop/ecommerce.html
this site is complete shopping suite right ?
Post by [RZ] » Sun Apr 19, 2015 8:43 pm
the magna-e-shop website was developed using the [rz] Shopping Suite
of course other extensions are involved, but all you need is available here: www.magnawebstudio.com/shop and for a technical information excerpt here: www.magnawebstudio.com/developer
mayur007
Post by mayur007 » Sun Apr 19, 2015 8:48 pm
thanx
Re: [rz] Shopping Suite *** UPD 2015-May-27 ***
Post by [RZ] » Wed May 27, 2015 2:01 pm
* New in version 1.0.3.3:
- Fixed an introduced silent focus bug in [rz] Shopping (b-monitor) module with no events.
- Added optional image-size definition to allow a better implementation in Retina-based devices.
- Improved payments panel alignment.
Post by zinc » Wed May 27, 2015 9:05 pm
A titanic effort from RZ to get all of these amazing tools updated. For those of you who are developing RWD sites with RZ tools, these new features are very very very important and hugely welcome!!! Thank you once again RZ :D
Good news everyone!
