[rz] iFrame v1.0.1
This set of extensions allows you to make an inline frame in a main page and open embedded pages.
The embedded pages won't be opened as standalone pages.
Automatically they will be opened from the main page.
Sample project files are included.
* NEW in this version: Allow transparency for backward compatibility with older browsers like IE8 or earlier.
DOWNLOAD
HTML 4.01 Transitional
W3C compliant
How to use?
[rz] iFrame (main)
Build your main-page and insert an inline frame from the "(main)" extension.
You can specify the appearance of the inline frame as you set-up the wb's standard ones.
[rz] iFrame (subp)
Build your sub-pages to be embedded in the main-page.
Insert the "(subp)" extension in each one and indicate what is the main-page that embeds these sub-pages.
[rz] iFrame (subp) tiny
Build your sub-page and add this extension to it as to avoid running as standalone.
If you have two or more inline frames in the main page, you must run this tiny extension instead of the regular "(subp)".
This is the current limitation for this iFrame extension version.
Enjoy!
inline frame - sub-pages won't open as standalone ones
- [RZ]
Re: inline frame - sub-pages won't open as standalone ones
hi RZ,[RZ] wrote:@jordan
... just i wanted to remember you, may be some users find it useful ...
I totally missed this, croink!, thanks for a reminder RZ
you can always drop me a mail if you want to, top post index is my email, but normally I keep up, missed this one though .
- [RZ]
didn't see itjordan wrote:top post index is my email
best regards!
it is written at the beginning of the index (1st sentence after "WB INDEX") and at the end in the declaration of HELP .
so … uuuh, yes, you are getting old … but so am I, I missed this one .
@ [RZ]
I've found an issue with this extension.
The width of the extension container is wider than the actual iframe by 12 pixels.
Please can you correct this and update the extension?
- [RZ]
thank you for your post and your interest in this extension.
i'm sorry, this is a technical limitation and there is nothing i can do about it.
i tried to make a workaround, in some extensions worked fine, in others was not so easy... the final code has grown needlessly up (carrying other downsides and innacuracies).
anyhow, i will try to do my best to fix this if the issue remains in the next extbuilder version. however, i talked about this with pablo, and i'm afraid he can't change this unless other rendering methods will be used.
hope you can understand.
thanks and regards.
thanks and regards.
- [RZ]
sorry for the inconveniences... download link restored.
Good sharing. Will work with external url link?[RZ] wrote:sorry for the inconveniences... download link restored.
Buy Automation Shopping Cart for CMS WEBSHOP + 2.2 Using WB10!
- Use secure gateway to buy using PAYPAL website.
- [RZ]
thanks!adex1 wrote:Good sharing. Will work with external url link?
from the first post:
this means that you must have the control over the page to be embedded, in other words, you must add/edit/adapt in a way such a page. you can point to an external site as long as you can add the extension.
Hi there. How can I download these extentions? It says you have to "request"
- [RZ]
hello;
the extensions are available here: www.magnawebstudio.com/shop
