CMS Login Issue
CMS trouble shooting / FAQ:
viewtopic.php?f=10&t=43245
BethlehemOffice
CMS Login Issue
Post by BethlehemOffice » Wed Sep 20, 2017 1:43 pm
Ok, I set up a login system and it worked just fine when I used automatic verification. I changed to email verification and now it doesn't work so well.
I was able to create an account but when I used the email link to verify the account the response I get is "User not found". It doesn't show up in the SQL table so I get why I am receiving that response but why isn't it creating the user in the first place? Is there another field I need to add to the data table to make the verification by email work?
Side question, is the verification email encrypted? It shows Username and password in clear text so I'm a little worried about security.
Re: CMS Login Issue
Post by Pablo » Wed Sep 20, 2017 1:59 pm
Maybe you have changed something else too?
Does it work when you change back to automatic verification?
Are there any errors in the server PHP log?
The email is sent by the mail server of your host.
BethlehemOffice
Re: CMS Login Issue
Post by BethlehemOffice » Wed Sep 20, 2017 11:24 pm
I did add a field. I forgot about that. Works now. THANKS!!!!
Jorus
Re: CMS Login Issue
Post by Jorus » Mon Mar 26, 2018 1:36 pm
I have the same problem with the 'User not found!' message after selecting the link from the email.
What 'field' did you forgot to add?
Re: CMS Login Issue
Post by BaconFries » Mon Mar 26, 2018 1:45 pm
You may not get a answer soon from the original poster as Last active:Tue Sep 26, 2017 4:53 pm. It wasn't that they forgot to add field, it was that they had forgot they had 'added' a field.
Jorus
Re: CMS Login Issue
Post by Jorus » Mon Apr 09, 2018 12:47 pm
Thanks to pablo, I now understand 'Bethlehemoffice' and your comment. Indeed me to I wasn't aware that I've had added an extra field in the Signup Form(!) which needed to be added in the MyAdmin (database) Now everything works, thank you.
