Trying to get CMS admin working
CMS trouble shooting / FAQ:
viewtopic.php?f=10&t=43245
caliways
Post by caliways » Sat Dec 17, 2016 8:52 pm
Hello,
Hope you all are doing well, I was able to duplicate this problem twice, once on the web server and on the xampp local install. When I login the tables are made in the database but I do not get any of the control buttons for new page, edit ... I turned on the error reporting and here is the results.
Notice: Constant BLOG_LABEL_EDIT_CATEGORY already defined in E:\Xampp\htdocs\dataproject\plugins\blog\plugin.php on line 51
Notice: Constant MODURATION_MESSAGE already defined in E:\Xampp\htdocs\dataproject\plugins\comments\plugin.php on line 13
Notice: Constant MODURATION_SUBJECT already defined in E:\Xampp\htdocs\dataproject\plugins\comments\plugin.php on line 14
Warning: mysql_query() expects parameter 2 to be resource, object given in E:\Xampp\htdocs\dataproject\plugins\blog\plugin.php on line 312
This is the tutorial I followed to make the CMS admin
https://www.youtube.com/watch?v=ygLtY1wusvw
Thank You
Re: Trying to get CMS admin working
Post by Pablo » Sat Dec 17, 2016 9:37 pm
Please start without the plugins first.
You will have to make sure the basics are working before you implement advanced features.
caliways
Post by caliways » Sat Dec 17, 2016 9:43 pm
Thank you Pablo for your help, I will check that out and post back with results.
caliways
Post by caliways » Sat Dec 17, 2016 11:22 pm
I found blog plugin will not work, all the others do. Also found that you have to delete all the files W11 generates into the public_html folder is something goes wrong and then re-generate with the blog module turned off. Then you can login and make pages. Also seems that the blog plugin wants at least one blog category made, could that be what is wrong? It also seems the blog tables are not getting made, that would explain it. How do I get the blog tables made?
Thank you
Post by Pablo » Sun Dec 18, 2016 8:28 am
The blog plugin should not be included in the plugin folder, it is an unfinished script. Please remove it from your computer.
