No plugin configuration tabs
CMS trouble shooting / FAQ:
viewtopic.php?f=10&t=43245
netmarketer
Post by netmarketer » Tue Jan 19, 2016 7:53 pm
Hi... I added 3 plugins to CMS Admin but the configuration tabs are not showing.
From http://www.wysiwygwebbuilder.com/cms_plugins.html it says "the 'admin' part will be loaded by the CMS Admin and display a configuration tab", but this is not happening and I am unable to configure any of them.
If I click on the Plugins link on the menu, all 3 are showing, but not the tabs. Only the General tab is showing.
Maybe a bug?
Re: No plugin configuration tabs
Post by Pablo » Tue Jan 19, 2016 9:23 pm
What did you do?
Which plugins did you install?
Not all plugins have tabs. This is not a bug.
netmarketer
Post by netmarketer » Tue Jan 19, 2016 9:48 pm
Plugins are:
File Manager
Plugin Manager
User Manager
How would I configure File Manager if there is no tab?
Post by Pablo » Wed Jan 20, 2016 7:33 am
There plugins do not have a tab, because they do not apply to pages.
netmarketer
Post by netmarketer » Wed Jan 20, 2016 7:16 pm
How is the File Manager plugin configured?
Post by Pablo » Wed Jan 20, 2016 7:26 pm
You can change the behavior of the plugin by editing the code of the plugin.
netmarketer
Post by netmarketer » Fri Jan 22, 2016 3:51 pm
"File Manager plug-in Implements a basic file manager to upload files. The default folder is 'files' but you can change this by editing the plugin file (plugin.php)."
Here is plugin.php:
<?php
$plugin = array(
'name' => 'File Manager',
'description' => 'Implements a basic file manager',
'admin' => array('menu' => array('File Manager' => 'adminform'))
How should this be edited? There is no default folder called "Files".
When I try to upload a file I get this:
File upload error: Upload failed, please verify the folder's permissions.
What folder is referred to here? The Filemanager folder is 777, so that can't be it.
Post by Pablo » Fri Jan 22, 2016 4:06 pm
Settings can be changed in 'adminform.php'.
This is for advanced users only. Change at your own risk.
There is no support on modified plugins.
This is the folder configured in adminform.php.
netmarketer
Post by netmarketer » Fri Jan 22, 2016 6:30 pm
Went through the adminform.php.
Even when I create the 'files' folder myself (it's not created by the plugin itself) and give it full permissions, still the same error.
Does anyone support this plugin?
Post by Pablo » Fri Jan 22, 2016 6:59 pm
Did you create the folder in the right location on the server?
This can only be a configuration issue.
netmarketer
Post by netmarketer » Fri Jan 22, 2016 8:27 pm
You are right. I moved it to the root directory from the File Manager directory and it works now.
Thanks again.
