CMS Menu Order
CMS trouble shooting / FAQ:
viewtopic.php?f=10&t=43245
nathaninidaho
CMS Menu Order
Post by nathaninidaho » Fri Sep 18, 2015 9:01 pm
Hi All,
is there a code snippet that I can enter to make the cms menu order by create_date rather than menu_index? When I take the source code for the cms menu and paste it into an html box and change the "ORDER BY menu_index" to ORDER BY create_date that works - it's just that I need to to be able to calculate the dynamic height of the menu as it grows and I can't seem to be able to get my jquery script to calculate the dynamic height of an html box.... so if I can just adjust the 'ORDER BY' on the menu that would do the trick.
Is there any script I can insert to change that from ORDER BY menu_index to ORDER BY create_date?
Thanks!
Nathan
Re: CMS Menu Order
Post by Pablo » Fri Sep 18, 2015 9:25 pm
I'm sorry I cannot help you with custom coding. For me this may also take several hours/days to implement this functionality.
nathaninidaho
Re: CMS Menu Order
Post by nathaninidaho » Fri Sep 18, 2015 9:53 pm
Support,
I completely understand and appreciate your prompt reply.
Thanks!
Nathan
Hurtado
Re: CMS Menu Order
Post by Hurtado » Sat Jun 25, 2016 6:47 am
Yo can use a jQuery plugin for that
