Actor - Responsive Template made with WWB14
Please post free templates here
ashutoshkushwaha
Post by ashutoshkushwaha » Sun May 13, 2018 6:49 pm
I'm new to WWB14 and still learning to use it to get the best out of it. I have created my first template and I'd like to share it with you guys as a free template. I hope you would like it. I have added two breakpoints in it to make it responsive. :D :D
Download Link: http://www.mediafire.com/file/p5ucz49xm ... mplate.rar
Use winrar or 7-zip to extract the downloaded file.
Google Fonts Used (Available in WWB14):
Abel
Akronim
Arizona
Extensions Used (available in WWB14):
Justified Gallery Extension (With VENOBOX lightbox effect, keyboard arrow key navigation and touch navigation supported)
Unite Gallery Extension
Live Preview: https://ashu-test-website.000webhostapp ... index.html
Full Screen Screenshot link: https://4.bp.blogspot.com/-Hle_fVghsiI/ ... mplate.png
Note: Most of the images used in the template are copyright free and a few are taken from Google images and can be used for wallpaper purpose and demonstration purposes only. Users are requested to change the images with their own images before using the template commercially.
Last edited by ashutoshkushwaha on Tue May 15, 2018 5:17 am, edited 3 times in total.
Ashutosh Kushwaha
Re: Actor - Responsive Template
Post by BaconFries » Sun May 13, 2018 8:37 pm
Thank you for sharing. Regarding all images used, do you have the right (copyright) to distribute the images you have used?
When posting, you need to state that the images can be used are copyright free and can be freely used, if not you are rwq5 to write this in your post and include in the terms of use with the template.
ashutoshkushwaha
Post by ashutoshkushwaha » Mon May 14, 2018 2:43 am
Thanks for suggesting. I've added a note in the post here.
Ashutosh Kushwaha
valers
Re: Actor - Responsive Template made with WWB14
Post by valers » Fri Sep 07, 2018 10:08 pm
This template doesn't open in version 14
ashutoshkushwaha
Post by ashutoshkushwaha » Wed Oct 03, 2018 3:56 pm
I've made the template with WWB14 only. Please check if your WWB is working properly. If there is any error message while opening the template, let me know.
Ashutosh Kushwaha
basstuuk
Post by basstuuk » Thu Oct 04, 2018 6:49 pm
Hey,
The template works perfectly for me.
Windows 10, WB 14.2
Greeting Bas :D :D
WiekensJan
Post by WiekensJan » Sun Dec 23, 2018 9:03 pm
Same here. Not working with wb14
basstuuk
Post by basstuuk » Mon Dec 24, 2018 6:16 am
The template works fine with me in version 14.3
Did you install the extensions.
Greeting Bas :D :D
