Free template: Minimalistic yellow
Please post free templates here
filmphotog
Post by filmphotog » Sun Sep 13, 2015 2:27 pm
Free WYSIWYG Web Builder template: Minimalistic yellow
This template in similar design as my template Minimalistic green, but uses Master Frame for simplicity. Perhaps someone is interested in using this template as a start and continue to modify the pages.
Terms of use: Free
Extensions needed: Responsive Drop Down Menu 1.0.0 (by Pablo Software Solutions)
No licensed images were used, the pictures were taken by me earlier today and are free to use.
Responsive Web Design
- 5 breakpoints, 320 480 768 1024 1280 (the two largest are reduced to 994 and 1250 for scrollbars in browswers)
- Master Frame is used for all pages (two master frames because of different links in the menu)
- Startpage and 4 additional pages
- Carousel - replace pictures with 1250x703 pixels (16:9 format), or use them.
- Navigation pictures - replace pictures with 140x93 pixels (3:2 format), or use them.
When replacing pictures select properties and choose another image source.
It's best to check View-->Object Outlines because objects in the master_frame are grey on grey and are hard to see without the object outlines.
Fully functional demo
Template for download
Hope this template is useful, thanks.
