I was so excited to test some of the new features introduced through WWB16 on a new project that I'm working on, and one of them is the Dividers. Sadly only to discover that the Dividers are not responsive. Meaning, on smaller breakpoints, the dividers width and heights properties remains unchanged, therefore blocking the rest of the content on the layer. I tired everything in the book but no joy.
Is there a workaround this?
Dividers not responsive
- crispy68
Re: Dividers not responsive
Currently there is not within WB. However, I created this if interested:
http://www.wysiwygwebbuilder.com/forum/ ... 59#p451159
- wwonderfull
with some learning you can also create your own dividers if you want. It gives you your perfect choice and for that here is a tutorial on how to make dividers and use them in wwb https://www.wysiwygwebbuilder.com/forum ... 26&t=89921
Thanks you crispy68, just purchased the extension and voila, it works. Good stuff!
thanks wwonderfull, good tutorial but I was after something less complicated. Thanks heaps for sharing anyway.
