CSS menu layout space - not working in ver 15.4.5
longman
Post by longman »
Hi pablo,
My CSS menu in the previous 15.1 version was working just fine, I had put a little space between menus, but as soon as I installed the new version, the little space does not appear when I preview/publish my site, although within the software it does appear.
Screenshot 1 http://prntscr.com/u8swik
Screenshot 2 (Preview) http://prntscr.com/u8sy88
A bug I guess?
Thank you!
longman
Re: CSS menu layout space - not working in ver 15.4.5
Post by longman »
I should also add that in breakpoint (768) the space will appear correctly.
So only in horizontal the space will disappear
longman
Post by longman »
Here is the example WWB file attached https://filebin.net/bnt4wqh7sgl4xuw9/Un ... t=pt5jffo9
This issue has been fixed in the latest build of WB15.
