problem with new update
Rass
Post by Rass » Sat Jan 18, 2020 10:29 am
Dear Pablo after upadating to 15.2.3, WB doesn't open any project already created with 15.2.2 version. My OS is the latest Windows.
Re: problem with new update
Post by Pablo » Sat Jan 18, 2020 11:27 am
Version 15.2.3 is just a minor update compared to 15.2.2, there were no changes to the file format.
If there an error?
Do you have an example project?
Rass
Post by Rass » Sat Jan 18, 2020 11:42 am
Thanks Pablo, yes, there is an error saying: "JUSTIFIEDGALLERY" could not be loaded. I have already reinstalled the referred extension. Then, there is another message: "Make sure you install the same application or newer as the one used to create the project
Rass
Post by Rass » Sat Jan 18, 2020 11:50 am
Where should I send you an example of the project?
bkjohns
Post by bkjohns » Sat Jan 18, 2020 11:54 am
Download the correct version? (64bit or 32bit)
Rass
Post by Rass » Sat Jan 18, 2020 11:57 am
Tnanks for your kind answer, I have tried both versions
jerryco
Post by jerryco » Sat Jan 18, 2020 12:08 pm
Of the application or of the extension?
Post by Pablo » Sat Jan 18, 2020 12:21 pm
This error indicates that you did not install the 'justified gallery' extension. it's unrelated to the update.
Maybe you have installed the 64bit version but did not update the extension to 64 bit?
Rass
Post by Rass » Sat Jan 18, 2020 12:58 pm
Sending you the created project
bkjohns
Post by bkjohns » Sat Jan 18, 2020 7:56 pm
Are you opening the project from within WebBuilder, or double clicking a web builder file?
