15.2.2 ver. Shape opacity and Text distortion
CharlesAr
Post by CharlesAr » Tue Jan 07, 2020 9:24 pm
In version 15 and up when a shape background opacity is set on any parameter other than 100%, it causes in-shape Text distortion with artifacts.
jerryco
Re: 15.2.2 ver. Shape opacity and Text distortion
Post by jerryco » Tue Jan 07, 2020 9:27 pm
Did you enable Use anti alias text?
CharlesAr
Post by CharlesAr » Tue Jan 07, 2020 9:41 pm
Yes, I tried that. Doesn't help.
Post by Pablo » Tue Jan 07, 2020 9:44 pm
If you set the output format of the text to 'HTML' then the text will be exported as standard text.
Using 'default' will give the same results as in previous versions.
CharlesAr
Post by CharlesAr » Tue Jan 07, 2020 9:55 pm
Thanks for replying, but I tried all 3 options (default, HTML, and anti-alias) and no one fixed that. The text has a white snowy background which covers the text and it cannot be seen. Once I put the shape's background opacity to 100 that snowy white text background disappears.
Post by Pablo » Tue Jan 07, 2020 9:59 pm
Maybe there is an issue with your browser?
Because if you publish the text as HTML then the browser will dertermine the quality of the text.
Do you have a demo project?
What does it looks like for you?
CharlesAr
Post by CharlesAr » Tue Jan 07, 2020 10:03 pm
When I publish it looks fine. The issue is on the project screen. Here is the screenshot:
https://drive.google.com/open?id=17nHWz ... 0OVO-m2PcF
Post by Pablo » Wed Jan 08, 2020 7:16 am
I was not able to reproduce this behavior. For me, it works correct.
Maybe it's related to your graphics card or video drivers?
Do you have an other computer you can try it on so we can be sure it's not just an issue of your computer?
Or else can you share a demo project so I can see all you settings?
CharlesAr
Post by CharlesAr » Wed Jan 08, 2020 9:11 am
I will definitely try it on other machine and let you know how it is. But just want to say that there haven't been this issue found on the same machine with version 12. It was working flawlessly.
Post by BaconFries » Wed Jan 08, 2020 10:37 am
As it hasn't been asked yet what version of Windows do you have installed? If Windows 7 have you install Direct2d support? If not then see the following:
https://www.wysiwygwebbuilder.com/forum ... 10&t=86373
Do you have the latest update of the software 15.2.2 (32-bit /64-bit) installed see the following
CharlesAr
Post by CharlesAr » Wed Jan 08, 2020 3:13 pm
Yes, I have Windows 7 with SP1 and all other the latest updates installed. And yes, my WWB version is 15.2.2 64bit
Post by Pablo » Wed Jan 08, 2020 4:02 pm
Did you install Direct2d support as documented in the FAQ?
CharlesAr
Post by CharlesAr » Wed Jan 08, 2020 10:21 pm
Yes, the update is installed.
