Website publishing - not working
jerryco
Re: Website publishing - not working
Post by jerryco » Mon Jan 06, 2020 8:34 pm
It would be easiest if a true pro (I'm just being a fisherman here) could answer this for once and for all:
If I download the 64 bit and install it, will it ovverride the 32 bit - or run alongside - if so, I can try it on a copy of the project?
alan_sh
Post by alan_sh » Mon Jan 06, 2020 8:46 pm
It does NOT override the 32 bit.
Alan
WWBman
Post by WWBman » Mon Jan 06, 2020 8:47 pm
The 64-bit version installs in C:\Program Files.
The 32-bit version installs in C:\Program Files (x86)
They can run alongside each other.
But read the following regarding the 64-bit version:
https://www.wysiwygwebbuilder.com/forum ... =1&t=77283
alex4orly wrote:
Mon Jan 06, 2020 8:23 pm
NO, I was to be done by 7:00 am, and I AM NOT YET
I started a new project, and am copying pages from my original project to it, all the master frame menu links are gone...
The original project was already set to Winsock
I am using only the 32 bit version, the things that are written about the 64bit got me concerned and I never tried it.
Yes, the original project is huge - the project file is over 8MB, the new one is only 1.8MB - is that the reason?
Thank you all for your input, will wait and see
You said that the project now works so why are you considering the 64-bit version when it seems you are under pressure?
WWBman
Post by WWBman » Mon Jan 06, 2020 9:14 pm
I must add:
One thing to be aware of when running both versions is the version that Windows loads when the .wbs file is double-clicked is the version that was installed last.
So if you normally run the 64-bit version but install both versions then it's preferable to always install the 64-bit version last.
It's obviously safer just to open the .wbs file from within WWB.
alex4orly
Post by alex4orly » Mon Jan 06, 2020 10:27 pm
Thanks for the comments and response.
I have no intention to start with the 64bit now.
But, would like to experiment with it.
Yes, I allways select the web icon first and from it, open the project I want.
One other thing that I am puzzled about, when I imported the pages from my original project into the new blank project, I also imported the master frame, which has in it the menu.
At least half of the menu items were somehow now pointing to the wrong project pages and I have to go through all of them to check...
Why?
Thanks again
NarellanProbus
Post by NarellanProbus » Wed Jan 22, 2020 11:40 pm
My website is not uploading new pages. I just get Internet Exception Error 12003 Details: The server returned extended information 200....(cant read anymore),
Closing FTP connection, Removing temporary files, Publish failed, END OF PUBLISH.
I tried to rename the whole website and reloaded the whole thing but only the older pages are visible.
The FTP connection has tested OK. I have contacted my provider but they cant see there is an issue and suggested I contact you guys.
*** START OF PUBLISH ***
Scanning publish folder...
Found 21 file(s).
Initializing FTP connection...
Checking host...
Host was successfully parsed.
Connecting to ftp.narellanprobus.org.au...
Using PASV mode.
Succesfully connected.
Current directory is '/'
Setting remote folder to /public_html...
Status: 550 Can't create directory: File exists
Uploading 'font-awesome.min.css'...
Details:
200 TYPE is now 8-bit binary
227 Entering Passive Mode (203,28,48,10,223,210)
552 Disk full - please upload later
Closing FTP connection...
Removing temporary files...
Publish failed!
*** END OF PUBLISH ***
Needing help.
Post by Pablo » Thu Jan 23, 2020 7:18 am
The log indicates that the server disk is full:
tccieslak
Post by tccieslak » Sat Mar 28, 2020 2:12 am
I am trying to publish a relatively simple web page with a form that has about 10 fields on it and using the PHP processor for form processing. It shows correctly when I preview it, when I publish it there are no errors but when you bring the page up in the browser from the server, only half the page loads.
Also, is there a way to get the current date and time automatically put into an editbox or textarea with the user having to choose it?
Post by Pablo » Sat Mar 28, 2020 8:06 am
What is the URL of the page?
Also, can you please not 'hijack' another unrelated post?
