Tabel row height
colin1661music
Tabel row height
Post by colin1661music » Thu Dec 19, 2019 8:49 pm
Hi
Has anyone had any experiance of using tables, even though these tables (coloured grey) look fine in the editor, they are all over the place with large row heights in the browse. I've tried for 3 hours to adjust row hights but nothing works.
www.bespoke-blading.co.uk
Colin
Re: Tabel row height
Post by Pablo » Thu Dec 19, 2019 9:28 pm
To be able to help you, I need a demo project so I can see all your settings.
Related FAQ:
Post by Pablo » Thu Dec 19, 2019 9:57 pm
I have looked at your project and it looks like you have used the table in a responsive layout.
Unfortunately, HTML tables are not responsive. This means table cannot have a different layouts in breakpoints.
But I think that in this case you do not need a table, you can also use a layout grid with two columns.
colin1661music
Post by colin1661music » Thu Dec 19, 2019 10:12 pm
Thanks Pablo,
I converted them all to 2 column grid layouts and it works although it's not ideal on mobiles its much better now.
Keep up the good work.
Colin
