Hi All,
I have inserted break points on my page to establish a responsive design for my website. However when inserting a new layer this doesn't
seem to be responsive when clicking on the break points setup on the page.
Does anyone know how to make a layer responsive thank you
Best Regards
Paul
LAYER
- Williams
Re: LAYER
What do you exactly mean with
Hopefully this answer your question..
you have to resize the layer in your Breakpoints yourself. that's how it works. it doesn't look responsive like the layout gride.However when inserting a new layer this doesn't
- Bluesman
Re: LAYER
In first case... make the layer mode: Floating so it will work with other responsive objects...paul2811 wrote: Tue Sep 10, 2019 2:55 pm Hi All,
Best Regards
Paul
