*** SOLVED ***When I add an image it stays a little square.
derold
Post by derold » Thu Aug 22, 2019 5:38 pm
WB15
When I add an image it stays a little square. It does not snap to size. It will do it on one computer but not on the other.
I do know that I can right click and click on restore original size, But when the image is say 200px by 200px and I draw a box say 50 by 50 then add a 200 by 200 image it will automatically resize to 200 by 200 on one computer not on the other. Is there a setting that I need to change?
Re: When I add an image it stays a little square.
Post by Pablo » Thu Aug 22, 2019 6:19 pm
When you insert an image then it will be inserted at the specified position/size, unless the size is larger than the viewport in which case it will be scaled to fit.
If you want to insert the image with its original size then you can drag the image object from the toolbox to the workspace.
derold
Post by derold » Thu Aug 22, 2019 7:23 pm
OOOK I see Thanks!
