Importing settings from v14 --- including extensions
Smee
Post by Smee »
I've had the software since released, and just now having a chance to try it out.
On startup, I clicked to import settings.
One thing I noticed is it did not import my extensions I had purchased. Figured I would download them again, but the link has expired.
Wasn't this new version supposed to import these extensions --- especially the paid ones? Simple to download the free ones again, but kinda disappointed that I'll have to continue using v14 to have access to my extensions.
Any way I can try over again, or am I going to have to repurchase?
Re: Importing settings from v14 --- including extensions
For all extensions purchased (Pablo Software) you can re-download from here:
http://wysiwygwebbuilder.com/extension_update.html
All other paid/purchased extensions contact the relevant builder.
There is no need to 'import' extensions. If you have configured the same system folder (in tools->options->files & folders) then they will be available automatically.
However, extensions do not work in the trial version.
