Tab order
Trugmaker
Tab order
Post by Trugmaker »
Questions:-
How do I set tab order in a form? I can't find it in the tutorial
When I click on 'Set table order, six boxes have a blue mark (top left, but one of the boxes (3rd down) does not and is ignored
Never complain about getting old, the alternative is far worse!
Re: Tab order
Please see 'Set Tab Order in Forms' in the help.
Trugmaker
Re: Tab order
Post by Trugmaker »
OK got that sorted but two more queries. Why does it automatically add the IP address which is unrequired and why do I get two responses - the proper form and a second that comes in at the same time saying Values submitted from web site form:
Re: Tab order
You can disable the IP address in the form's properties.
Here you can also set other properties.
Trugmaker
Re: Tab order
Post by Trugmaker »
OK almost correct - I have set tab order and all correct, but when I test the email reply the order of the entries is incorrect. The first 5 entries are correct but what follows is entry 7 - 9 - 6 - 8. I have studied the Help but can find no solution. Also I have turned off the autofill but it still does it.
WWBman
Re: Tab order
Post by WWBman »
Right-click Form > Arrange Objects.
Trugmaker
Re: Tab order
Post by Trugmaker »
OK all perfection itself - just one more tiny insignificant question, can one control how the finished email visually appears when I receive the ie. Style - font size etc.? As it is just a list of edit box entries (all the info required but I would like the presentation of it a little more dynamic!
Re: Tab order
