*** SOLVED *** WB15 New Installation Problem
kibble
Post by kibble » Sun Jul 14, 2019 5:24 pm
I have just purchased V15 and when I try to run setup.exe I get the following message
Setup.exe is not a valid Win32 application.
I am running Windows XP and am still able to run V14 with no problem.
I have downloaded the zip file twice, in case it was a corrupted download.
Can you suggest anything that would sort this out for me.
Thank You
Re: WB15 New Installation Problem
Post by BaconFries » Sun Jul 14, 2019 5:38 pm
Sorry but Windows XP and including Vista are no longer compatible/supported by WB15. This is documented at the following
https://www.wysiwygwebbuilder.com/forum ... 4e7d8c8c65
Without being rude I can't understand why anyone is still using XP today... just my two cents.
Post by Pablo » Sun Jul 14, 2019 5:42 pm
Maybe you trying to install the 64bit version?
Also note that Windows XP is not supported.
kibble
Post by kibble » Sun Jul 14, 2019 6:46 pm
Ok thanks for the answer.
I did not see anywhere that XP is not supported in WB15 (maybe I missed it)
Can I get a full refund?
BaconFries - I found windows 7 to be unusable, Windows 8 not a lot better. Windows 10 is ok, but I don't want to spend lots of money on buying windows 10 and then updating my scanner, printer and some software I have bought over the years when XP does everything I need it to (except run WB15 :( ). I suppose that I know one day I will more than likely have to.
Pablo I downloaded from the link on the e-mail re WB15 upgrade information, it did not appear to indicate it was the 64bit version.
kibble
Post by kibble » Sun Jul 14, 2019 6:53 pm
Just re-read the WB15 update post that BaconFries pointed to.
Yes it does state in there that XP is not supported (due to Direct2D)
So, my mistake. I'll just have to save the downloaded WB15 until I eventually get Windows 10, maybe this will quicken up the process.
Post by BaconFries » Sun Jul 14, 2019 6:59 pm
From the url provided
Hardware acceleration/Direct2D
Unfortunately the switch to Direct2D also means that the software no longer works on Windows XP/Vista.
For the best results we recommend to use Windows 10. Although most functionality should also work with Windows 7 and 8
You should still be able to use all your old printer, scanner etc under Windows 10 along with your software. I still use Macromedia software such as Fireworks, Dreamweaver without any issues but can see your point. Also Windows 10 isn't all that expensive to buy, look on *Bay there are sellers who sell licences cheap under what is known as 'scrapage'. This allowing them to sell you a 'license' from a scrapped PC but to do so you will also receive a component from the 'scrapped' PC such as its Motherboard. It is your choice if you dont wish to upgrade and I respect that.
bobfletcher
Post by bobfletcher » Thu Jul 18, 2019 1:09 pm
I have tried to load WB15 and had no problem with 15.0.2 but when I loaded 15.0.3 (and 0.4) the installation goes smoothly but when I try to run the program something flashes up on the desktop and then nothing happens, no error messages just nothing. I am using W10 and had no problem with WB14 and previous releases. Has anyone got any ideas about what may be wrong?
Post by Pablo » Thu Jul 18, 2019 1:12 pm
This is most likely an issue with your virus scanner. Please make sure that webbuilder.exe is on the exception list or contact the makers of the anti-virus software for an update.
bkjohns
Post by bkjohns » Thu Jul 18, 2019 4:09 pm
How long are you waiting before giving up on WB15 starting? Mine took a while to come up the first time (and I did get the quick window flash very soon after starting the program).
bobfletcher
Post by bobfletcher » Fri Jul 19, 2019 9:20 am
Waited a long time so there is definitely something wrong. The 64 bit version of WB15 does the same thing. I'm using Windows Security and I've checked the Firewall (that's OK). WB14 still runs OK and WB15.02 did run OK but I've not kept the download file for that version so I can't try it again. I've just installed the very lastest W10 update but that did not solve the problem. Obviously there is some incompatibility somewhere but not sure what else to check. :cry:
Post by Pablo » Fri Jul 19, 2019 9:55 am
The 15.0.3 update does not have any major changes compared to the previous update.
Did you add webbuilder.exe to the firewall exceptions?
bobfletcher
Post by bobfletcher » Fri Jul 19, 2019 10:31 am
Yes,the FIrewall allows WB15. Actually I've just found a version of WB15.02 and this doesn't work either now but I think it did at one stage. One version of WB15 certainly worked as I loaded it and looked at the new functions. Think it must be a Windows update that is causing the problem but not sure. I'm using the latest Windows update and don't want to go back unless I have to. Tried to load the program after starting up W10 in safe mode but WB15 still wouldn't run.
Post by Pablo » Fri Jul 19, 2019 10:45 am
Did you check the logs of firewall / anti-virus to make sure it's not blocked?
I cannot think of anything else that prevents the software from running.
Your system should at least tell you why it does not work.
bobfletcher
Post by bobfletcher » Fri Jul 19, 2019 12:01 pm
Not sure if this helps
WYSIWYG Web Builder
Description
Faulting Application Path: C:\Program Files (x86)\WYSIWYG Web Builder 15\WebBuilder.exe
Creation Time: 19/07/2019 12:57:15
Problem: Stopped working
Status: Report sent
Problem signature
Problem Event Name: APPCRASH
Application Name: WebBuilder.exe
Application Version: 15.0.2.0
Application Timestamp: 5d21efb4
Fault Module Name: WebBuilder.exe
Fault Module Version: 15.0.2.0
Fault Module Timestamp: 5d21efb4
Exception Code: c0000005
Exception Offset: 00b2b67e
Extra information about the problem
Bucket ID: 2ace2623708080172fbbf0e5692c9986 (2286686103923366278)
WB14 works OK.
Post by Pablo » Fri Jul 19, 2019 12:36 pm
No, this does not give any useful information.
Maybe there is a corrupt file in the extensions folder?
You can try this:
- go to Documents\WYSIWYG Web Builder\ and rename the folder
Does it work now?
