How to stop parallax automatically in minor resolutions.
h3rnan
Post by h3rnan » Tue Jun 18, 2019 9:02 pm
Hello, there is some way that ... automatically disable the parallax effect in resolutions lower than 900px.
The web of a client has almost 50 pages, and in each one no less than 9 images with parallax ... if I must go to each break point and disable each parallax in each one ... it is very extensive.
That's why my question is .. if I can add globally or a variable that disables the parallax in resolutions lower than ej .. 900px.
Just as you can modify the speed of the parallax effect from "User Defined Variables".
Thank you.
Hernán Pena
Web Developer / IT Administrator
Re: How to stop parallax automatically in minor resolutions.
Post by Pablo » Wed Jun 19, 2019 5:57 am
I'm sorry, there is currently no way to disable parallax globally.
I will try to add this in the next version.
h3rnan
Post by h3rnan » Wed Jun 19, 2019 5:51 pm
Thanks!!
Hernán Pena
