Text box outline
Norfolkman
Text box outline
Post by Norfolkman » Wed Jun 12, 2019 1:05 pm
I have one text box which is displaying its outline in white on the page in web preview. Borders are set to 0 and padding also 0.
What is causing its outline to be displayed?
Many thanks.
Re: Text box outline
Post by Pablo » Wed Jun 12, 2019 1:45 pm
Norfolkman
Post by Norfolkman » Wed Jun 12, 2019 2:03 pm
If you look at beta.mundesley.org you will see that there is a thin white line through the bottom left corner of the flag and across the bottom of the image to the right. It is also running down the right hand side of the main text. It coincides with the boundary of the textbox.
Post by Pablo » Wed Jun 12, 2019 2:19 pm
The text does have a border.
Maybe there is a conflict in your settings somewhere?
Norfolkman
Post by Norfolkman » Wed Jun 12, 2019 2:29 pm
Thanks Pablo.
I had a width set to 1 in the styles!
All OK now.
