problems with versions 14.3.4 and 14.4.0
wb_gjg
Post by wb_gjg » Tue Jun 11, 2019 7:06 pm
Hello,
in the new version 14.4.0 (32bit), the main-menu is not shown,
and the carousel doesn't work at all. So I can't proof the
state of the bug in Version 14.3.4 which was promised to be solved
in v14.4.0.
In the version 14.3.3 (32bit) there were no problems like these.
Or did I made a mistake?
Do you recommend to make a complete new installation?
I only substituted the WebBuilder.exe - file.
Test project:
https://gjgtech.de/DownloadsTemp/gjgWeb ... t_J611.zip
true solution is welcome
Guenter
Re: problems with versions 14.3.4 and 14.4.0
Post by Pablo » Tue Jun 11, 2019 8:13 pm
You will need to do a full install, because several scripts have been updated.
wb_gjg
Post by wb_gjg » Wed Jun 12, 2019 9:15 am
Yes, I've made a complete new install and now
it seems all to be ok!
Thank you
