*** SOLVED *** Responsive Menu - "Link to" question
MGD4me
Post by MGD4me » Sat Apr 27, 2019 9:05 pm
I have been using a Mega Menu navigation bar, and I would like to replace this with the Responsive Menu instead. Mainly for the more modern look, and the ability to display icons, over a transparent background.
I have read a number of threads on this forum regarding the lack of 'hover' ability on mobile browsers, and i get that part. Where I am having an issue, is when there is a main item with sub menus, and someone clicks on the main item. With Mega Menu, clicking on the main item has no effect. Clicking on the main item in Responsive Menu results in a link to "somewhere".
In the Responsive Menu, under the General tab, where select the main item, and edit the 'link' options, the 'Link to' options allow 'External Web Address', 'Page in this project', and several others. But there is no way to NOT make a selection, as far as I can see. In the Help file, there is this note:
Tip:
Main items with sub menus should not have a link because then the click/touch will trigger the link instead of opening the sub menu (touch devices do not have 'hover' functionality).
My question, is... How do I NOT have a link? If clicked, I would like to have the sub menus displayed, similar to the way Mega Menu works, if possible.
Re: Responsive Menu - "Link to" question
Post by BaconFries » Sat Apr 27, 2019 9:17 pm
Where you normally place/insert the url/link simply replace with # or JavaScript:Void(0);
alan_sh
Post by alan_sh » Sat Apr 27, 2019 9:30 pm
Personally I just leave it at pages in this project and don't select a page. Is that wrong?
Alan
MGD4me
Post by MGD4me » Sat Apr 27, 2019 10:03 pm
Brilliant!! That solved the issue.
I tried both appraoches BF and both answers work (Chrome). I wonder if all browsers accept either one.
Re: *** SOLVED *** Responsive Menu - "Link to" question
Post by BaconFries » Sat Apr 27, 2019 10:12 pm
Both methods will work for all "modern" browsers, but for all older and for non Doctype HTML5 pages then using
JavaScript:Void(0); should be used.
