Page Properties missing Events in the Events Tab
Magical
Post by Magical » Wed Apr 17, 2019 5:24 am
I opened the properties of the index.html of an old project (from 4 months ago). The events tab should have had ondocument ready events, but there are no events. The Page HTML does have the following, but I have no way to correct it. The page works as it should, just the control elements are missing from the UI. Any ideas?
<script>
$(document).ready(function()
$('#wb_service-text').addClass('visibility-hidden');
$('#contact-text').addClass('visibility-hidden');
$('#wb_Swan_Icon').addClass('visibility-hidden');
$('#wb_swan_manor_value_text').addClass('visibility-hidden');
$('#wb_swan_manor_value_text2').addClass('visibility-hidden');
$('#wb_Card4').addClass('visibility-hidden');
$('#wb_Card5').addClass('visibility-hidden');
$('#wb_Card6').addClass('visibility-hidden');
$('#Card7').addClass('visibility-hidden');
$("a[href*='#home']").click(function(event) .....
Re: Page Properties missing Events in the Events Tab
Post by Pablo » Wed Apr 17, 2019 6:07 am
This code will be added automatically when you use CSS animations to make sure the objects are initially hidden.
If the Events tab is missing then you most likely have enabled 'Easy Mode'. This will hide advanced options: Menu -> View > Easy Mode.
Magical
Post by Magical » Wed Apr 17, 2019 2:50 pm
The code is already present in the HTML, but I cannot see it in the wysiwig UI. Its not under page_properties ->events for the page or any other CSS animation. That was my point. Last year I was able to see it and change it as I added new UI elements.
Post by Pablo » Wed Apr 17, 2019 3:14 pm
Correct. WWB will add it as part of the CSS animations.
No, this has not changed. The code is added because of animations in onscrollreveal or onscrollrevealpartial events.
If you have a good reason not to include the code then you can disable it by adding the following user defined variable:
$SCROLLREVEAL_AUTOHIDE$
false
at your own risk!
Magical
Post by Magical » Wed Apr 17, 2019 3:22 pm
I uploaded a test wbs http://www.d2biz.com/swanmanorassistedl ... _issue.wbs
The issue is on the index page. The bottom 3 cards are initially set to be hidden, and then as the user scrolls up they become visible.
But if you access the page properties - > events. There are no events at all, even though they exist in the generated html.
Post by Pablo » Wed Apr 17, 2019 3:27 pm
As expected, you are using onscrollreveal events. That is why the code is added.
The code is not caused by a separate statement, it is part of the onscrollreveal events and Animate (CSS3)
See my previous reply.
Magical
Post by Magical » Wed Apr 17, 2019 3:55 pm
Where do I control these? For example If i wanted card3 to remain visible and not activate on scroll? Where would I change that?
Post by Pablo » Wed Apr 17, 2019 5:36 pm
In the project you have shared, card is not controlled by event.
Maybe you meant card4, card5 and card6? These events are implemented in Bookmark1
Magical
Post by Magical » Wed Apr 17, 2019 6:56 pm
Thank you so much. Is there a faster way to read the wbs and find the properties instead accessing each item and looking at its events?
Post by Pablo » Wed Apr 17, 2019 8:18 pm
I'm sorry, there is no faster way.
