Centering Form in screen
terryfoster60
Post by terryfoster60 » Thu Jan 31, 2019 12:26 pm
OK - new to forms really.
I have created a form using the wizzard and need to center this on the scren whatever resolution is being viewed.
I can not appear to overlay the menu into a pane of the layoutwizard nor get it to move with the page.
Thanks in avance for any feedback.
Terry
Re: Centering Form in screen
Post by Pablo » Thu Jan 31, 2019 12:57 pm
Do you mean that you want to display the form in a popup?
You can do this by creating a modal layer or use a dialog.
Use the 'enable form' property to convert the layer/dialog to a form and place all form elements directly on the layer/dialog.
terryfoster60
Post by terryfoster60 » Thu Jan 31, 2019 1:14 pm
Thank you for that information.
It was not what I was after but a pop up form would be great.
are there any instructions how to do this in WYSIWYG?
Post by Pablo » Thu Jan 31, 2019 2:27 pm
Modal Layer:
1. Drag the 'Layer' object from the toolbox to the page
2. Set the 'Mode' to 'Modal Layer'
3. Activate 'Enable form'
4. Drag form elements to the layer
Dialog:
1. Drag the 'Dialog' object from the toolbox to the page
2. Activate 'Enable form'
3. Drag form elements to the dialog
terryfoster60
Post by terryfoster60 » Fri Feb 01, 2019 1:07 pm
Is it not possible to place a form in the centre cell of a three column layoutgrid
Terry
Post by Pablo » Fri Feb 01, 2019 2:09 pm
A form cannot be inside a layout grid because a form is a fixed /absolute container.
However, the layout grid itself can be a form.
Related FAQ:
viewtopic.php?f=10&t=71391
