page language - can we add more?
longman
Post by longman »
Is there a way to manually add a language that is not listed in the software? I mean site properties, I wanna add a language that does not exist.
Thanks!
Re: page language - can we add more?
You cannot add languages to the list.
But alternatively you can add the language code via Page HTML.
As Pablos reply and if you require to add the language in the html tag as such <html lang="en"> then simply add an HTML object to the page and select 'Inside <html> tag'
longman
Post by longman »
but will it overwrite the previous language set by the software in site properties?
longman
Post by longman »
English is official second-language in Malaysia, wanna add En-My language
longman
Post by longman »
yea it worked, i selected none in site properties and added following code:
<html <html lang="en-my">
Thanks BaconFries and Pablo!
longman
Post by longman »
i guess i should only add this code:
lang="en-MY"
and select Inside html tag.
Then looks fine on page html preview.
lang="en-MY"
Correct!
