*SOLVED* Really scared I'm going to mess up something (32-bit/64-bit)
etcbbu
Post by etcbbu » Fri Jan 04, 2019 7:21 pm
Hi all,
I've got several projects/several websites on my system, where I use .WBS files and WYSIWYG Web Builder to work on these projects.
I'm currently using WB Version 14.2.2 , and things are working well.
I want to update to the newest version of the WYSIYWG Web Builder software, which, at *this* time, seems to be listed on the
http://wysiwygwebbuilder.com/download.html
as
Download the latest version of WYSIWYG Web Builder 14 (build date: December 20, 2018)
WYSIWYG Web Builder 14.3 (32-bit version)
WYSIWYG Web Builder 14.3 (64-bit version)
But, I want to really make sure that I download the correct one, and I do not want to mess up all of my projects or anything.
On my system, when I navigate to
My Computer >> Properties
Here is a screenshot of what is shown:
https://www.ktravisj.com/img1.jpg
Do I need to download and install the 32-bit version or the 64-bit version?
If something goes wrong after I install this, what can I do to either revert or roll-back my WYSIWYG Web Builder version, or something, such that I can use my .WBS projects again?
www.ktravisj.com
Travis J Consulting, LLC -
Website Design/Development/Maintenance, Web-Marketing/Social Media/Social Networking, SEO/Search Engine Optimization
www.ktravisj.com
Re: Really scared I'm going to mess up something (32-bit/64-bit)
Post by Pablo » Fri Jan 04, 2019 7:27 pm
The 32bit version is the regular version, the one you are used to...
etcbbu
Post by etcbbu » Fri Jan 04, 2019 7:32 pm
So I can keep running the 32-bit one, even though my system, there, says, "64-Bit" ?
www.ktravisj.com
www.ktravisj.com
Psycho
Post by Psycho » Fri Jan 04, 2019 8:32 pm
Exactly right
The 32bit version will run on both 32bit & 64bit machines without issues, so if that is the version you have been using, then simply stick with it
I have enough money to last me the rest of my life - Providing I die by next Tuesday
etcbbu
Post by etcbbu » Fri Jan 04, 2019 8:43 pm
@Pablo and @Psycho -- thank y'all.
Can someone tell me a high-level crash-course on what the point is, in have a 32-bit and a 64-bit version of a piece of software? Is it just that, an operating system that's 64-bit sort of handles the memory allocation associated with running the application / or handles the processes/memory/system resources in a more efficient way or a faster way than running a previous 32-bit version of that same piece of software, or something? Does that mean, in theory there would be fewer crashes, or something, in running a 64-bit version of a piece of software than a 32-bit version of a piece of software or something..?
www.ktravisj.com
www.ktravisj.com
Psycho
Post by Psycho » Fri Jan 04, 2019 9:00 pm
Have a look at the link below paying particular attention to the heading of "Software"
https://techterms.com/help/difference_b ... it_systems
Hope this helps a little more
etcbbu
Post by etcbbu » Fri Jan 04, 2019 10:41 pm
@Psych -- thank you!
:D :D :D WYSIWYG Web Builder is the BEST! :D :D :D
www.ktravisj.com
www.ktravisj.com
