Delay Card display on mouse over
Magical
Post by Magical » Tue Jan 01, 2019 2:48 am
Some of the images I am putting on a site require acknowledgement of the creator. What I looking to do is:
When the user has the mouse over an image/icon for more than 15 seconds then the site should show a Card with the acknowledgement.
I have looked a the events: 1) onmouseover, and 2)timerstart , but cannot figure out how to get them to work together. The timer would need to be set and reset once the user moves off the image/icon. At 15 seconds the timer should display a Card with acknowledgement.
Would appreciate any assistance. Thanks.
Re: Delay Card display on mouse over
Post by Pablo » Tue Jan 01, 2019 9:27 am
You can start a timer via events. Did you try that?
Otherwise you will need to implement your own custom script.
Magical
Post by Magical » Tue Jan 01, 2019 5:59 pm
I got it, used the event to start the timer, then added a timer object.
<a href="#" onmouseover="TimerStartSwanIcon();return false;"><img src="images/swan (3).png" id="Swan_Icon" alt=""></a>
Clear the event onmouseout.
Post by BaconFries » Tue Jan 01, 2019 8:05 pm
Please also read from the url below about naming objects such as images they should not contain brackets ( ) or any spaces. This will save you posting about images not showing when published if you have issues.
Invalid
Valid
src="images/swan3.png
http://wysiwygwebbuilder.com/forum/view ... 10&t=64868
Magical
Post by Magical » Wed Jan 02, 2019 2:22 am
Thank you!
