Card not rendering
Magical
Card not rendering
Post by Magical » Sun Dec 30, 2018 7:17 pm
I placed 3 cards on a layout grid, which has 3 sections. With the existing page the cards do not display. When copy the entire layout grid and place it on a new blank page then the cards show up. What am I missing?
Project file is at the following location:
http://d2biz.com/swanmanor_issue.wbs
To recreate:
1 - Download from above link
2 - Open project in Ver 14.xx
3 - Hit preview
4 - Expectation is to see the 3 cards
Re: Card not rendering
Post by Pablo » Sun Dec 30, 2018 9:07 pm
In the page properties events are used to hide the cards: The style 'initially-hidden' is applied.
The idea behind using this style is to hide the objects before they come into view.
However, it looks like you have removed the events that do that!
Magical
Post by Magical » Sun Dec 30, 2018 9:09 pm
I didn't remove anything, I just dragged the card object over, made the appropriate changes, and put it inside the layout grid. When I copy that layout grid to another page it works. But not on this page.
Post by Pablo » Sun Dec 30, 2018 9:18 pm
Please remove the events from the page properties.
They are set up to hide the cards!
Magical
Post by Magical » Sun Dec 30, 2018 9:22 pm
Yep! It looks like a Flower template issue. There are bunch of events there.
Post by Pablo » Sun Dec 30, 2018 9:44 pm
It is not an 'issue'. The events were added with a purpose. However, if you modify the page structure by adding/removing objects then you should remove them.
Magical
Post by Magical » Sun Dec 30, 2018 11:17 pm
Works! I removed the events. Thanks!
