I downloaded Webbuilder14 on a second PC. A message goes along the top it says something like "this version is incompatible" when I load the Website prototype. When I try and preview the website on the second PC I receive the error message "file not found" when I try to navigate the website from the second PC and a blank webpage.
The second PC is at the Clients location. I will be there today or tomorrow sometime. I can grab screenshots.
WYSIWYG Web Builder 14.1.1 not compatible with 14.2.2
Re: WYSIWYG Web Builder 14.1.1 not compatible with 14.2.2
If you save the project in 14.4.2 then you cannot open it in 14.1.1, because version 14.2.x has features that do not exists in 14.1.x.
'File not found' most likely means that you did not enable "preview the entire website''
Related tutorial: http://wysiwygwebbuilder.com/preview.html
That fixed the problem (preview entire website). How can I update the 14.1.1 to 14.2.2 on my main computer? Do I need to reinstall it?
You can install the update over the previous version.
