Modal Layer is behind the Page header
ruel.lago22
Post by ruel.lago22 » Fri Aug 17, 2018 5:20 am
Hi Pablo,
I have a question in regards to the Page header mode: Fixed with Stack level: in front of content. It goes in front of the Layer Mode: Modal layer with Model type: bootstrap and it looks ugly and it cuts the upper part of the Modal layer. How can we fix this? Thank you in advance!
Re: Modal Layer is behind the Page header
Post by Pablo » Fri Aug 17, 2018 6:41 am
Correct, that is the purpose of this option. The only way to prevent this is by (manually) giving the modal layer a higher z-index.
ruel.lago22
Post by ruel.lago22 » Fri Aug 17, 2018 7:50 am
higher z-index.
Where can I find the z-index Pablo? Thanks again!
Post by Pablo » Fri Aug 17, 2018 7:57 am
You will need custom code for that.
The exact code depends on the settings of your dialog.
ruel.lago22
Post by ruel.lago22 » Fri Aug 17, 2018 8:24 am
Uhmmm... I tried to do some research and put a custom code
 z-index:77777;
in the dialog object html: custom style but nothing happens even I make the number in millions. I hope you can help :D :D :D (cross-finger)
Post by BaconFries » Fri Aug 17, 2018 8:36 am
Page HRML Between <head></head>tag*
<style>
#Layer1
   z-index: 8888 !important;
</style>
ruel.lago22
Post by ruel.lago22 » Fri Aug 17, 2018 8:46 am
<style>
#Layer1
</style>
OMG!!! Haven't anyone told you that you are a rockstar! Thank you so much BaconFries!!! It worked!!!
Post by BaconFries » Fri Aug 17, 2018 9:19 am
I have been called may things...but a rockstar is on of the more friendly...😅 Note if using more than once on same page then you need to change #Layer1 to Layer2 etc.
Magical
Post by Magical » Mon Sep 03, 2018 3:15 pm
I have the somewhat similar issue. I dropped the Newsletter dialog on the main page which is using a master_frame. The dialog box is stuck on the top and inside the menu.
I added this
<style>
#Layer1
</style>
but still stuck. Click on the URL and you can see it at very top.
http://d2biz.com
Post by Pablo » Mon Sep 03, 2018 3:26 pm
Where exactly do I need to look for the dialog?
Post by BaconFries » Mon Sep 03, 2018 3:29 pm
About to ask the same!
Magical
Post by Magical » Mon Sep 03, 2018 4:32 pm
On the home page its at the very top - faded and merged in with menu bar.
Magical
Post by Magical » Mon Sep 03, 2018 4:38 pm
Here is an image of it Image
Post by Pablo » Mon Sep 03, 2018 4:58 pm
There seems to be something wrong with the style sheet.
Please set all HTML formatting options (Tools->Options->HTML) to their defaults and remove any custom code you may have added.
Magical
Post by Magical » Mon Sep 03, 2018 5:15 pm
I removed the custom code - which were master_frame:
between head and /head
<!-- Insert Google Analytics code here -->
<!-- Global site tag (gtag.js) - Google Analytics -->
<script async src="https://www.googletagmanager.com/gtag/j ... "></script>
<script>
window.dataLayer = window.dataLayer || [];
function gtag(){dataLayer.push(arguments);}
gtag('js', new Date());
gtag('config', 'XA-96858582-1');
</script>
AFTER BODY TAG
<div id="fb-root"></div>
<script>(function(d, s, id) {
var js, fjs = d.getElementsByTagName(s)[0];
if (d.getElementById(id)) return;
js = d.createElement(s); js.id = id;
js.src = 'https://connect.facebook.net/en_US/sdk. ... sion=v2.11';
fjs.parentNode.insertBefore(js, fjs);
}(document, 'script', 'facebook-jssdk'));</script>
And now it works.
