Mobile Browser Detector in Ver 14
MartinPorter
Post by MartinPorter » Wed Aug 15, 2018 1:56 pm
Hi Everyone..
And before anyone says it - I'm upgrading all my sites using "Breakpoints" but it's taking its time.
So back to it.. I have a site with about 20-30 standard pages and therefore have the same amount of pages
in a mobile size. In the last version 12, I used the Mobile Browser Detector addon which worked very well
(not has good as using Breakpoints) but it worked. I came to modify one of the pages using version 14 saved
the project and was told that once I save-it, you can't go back to old version. not a problem with that. So uploadled
the site, tested the mod I did and everything was fine. I never thought of about having a look at the mobile site
until I was told that on every device its loading the main screen and not the mobile side.
the script is on every page, and reads " var mobile = (/iphone|ipad|ipod|android|blackberry|mini|windows\sce|palm/i.test(navigator.userAgent.toLowerCase()));
if (mobile) {
document.location = "./MyMobileMenu.html";
So anyone know if this addon still works on Ver14? or is something being added to ignore script?
thanks for help..
Regards
Martin....
Re: Mobile Browser Detector in Ver 14
Post by Pablo » Wed Aug 15, 2018 4:09 pm
I doubt that this has anything to do with WB14.
But maybe you have enabled one of the HTML/JavaScript formatting options in Tools->Option->HTML?
Or maybe you have added other conflicting script to the page?
MartinPorter
Post by MartinPorter » Wed Aug 15, 2018 9:48 pm
spot-on again Pablo - I reset the HTML/JavaScript options saved the site then upload it again and Bingo.. worked first time :D
thanks for your help! Pablo
Regards
Martin...
Thanks & regards
Martin....
