One small problem with Ver 14
MartinPorter
Post by MartinPorter » Thu Aug 09, 2018 9:09 pm
Hi Everyone..
Upgraded to ver 14 just a few weeks ago and have come across a small error - it wont let me remove
the "Built-with" logo - been working on a new site and it still showing on
on line 7 - <meta name="generator" content="WYSIWYG Web Builder 14 - http://www.wysiwygwebbuilder.com">
Can someone help me on this?
thanks & regards
Martin...
Thanks & regards
Martin....
Re: One small problem with Ver 14
Post by BaconFries » Thu Aug 09, 2018 9:20 pm
This is not a error or a small problem at all with v14 this is how it works and is meant to show. The metatag at line 7 has nothing to do with the Built-with logo (which is a image). Anyway to remove the metatag if you do not wish it then Right click on page select Page Properties->Meta Tags-> Generator and simply remove/delete
WYSIWYG Web Builder 14 -http://www.wysiwygwebbuilder.com or delete and insert the url of your own site in its place.
Post by Pablo » Fri Aug 10, 2018 6:34 am
See also this related FAQ:
viewtopic.php?f=10&t=7794
MartinPorter
Post by MartinPorter » Fri Aug 10, 2018 10:14 am
Thanks Pablo & BaconFries all sorted..
Thanks & regards
Martin....
