Ready-to-use-java scripts- typewriter deluxe
ridvan
Post by ridvan » Sun Aug 05, 2018 9:35 am
Dear Pablo,
I have a problem Ready-to-use-java scrip "typewriter deluxe" at different breakpoints. I know it is not a responsive object, but it's also not pushing down in the below object on the small screen.
do you have any idea of solving this problem?
Thanks.
Re: Ready-to-use-java scripts- typewriter deluxe
Post by Pablo » Sun Aug 05, 2018 10:55 am
What exactly did you do?
ridvan
Post by ridvan » Sun Aug 05, 2018 11:54 am
At the beginning of the page I use "ready-to-use javascript, but javascript does not behave in different breakpoints as it does on the main page.
Default places where he does not fit pushes the following objects down but does not do it at other breakpoints.
Post by Pablo » Sun Aug 05, 2018 1:33 pm
In that case, I suppose the script does not support breakpoints.
